I'm going to be changing my coolant (99 Boxster). Does anyone know what size of the allen wrench it's going to take to remove the coolant plug?
John
Edited by johnj65
John- A 5mm hex should fit. Be careful not to strip and be sure to use anti-seize when replacing.
Gus
+1 on using anti-seize. Also be aware that the plug has a small aluminum crush ring on it, which should be replaced. Only cost a couple of cents, but can be a source of leaks
Where can I purchase the washer? Can't seem to find it anywhere.
John
Dealer only item, buy a bag full of them, they only cost a couple of cents each.................We get ours out of Sunset Porsche in OR..
