Hi, I am switching back to my electric spoiler from a fixed one, and put back the original harness,
but there is an extra connector in this one, one for light, one for fan, and where does the other one plug in??
thanks
Nevermind, Its spoiler brake light connector.
But Loren, I am in the process of removing some mods from the car since its going for a trade...
I took off my evo cold air intake, and installed my oem, but now the car starts up fine but 2 sec later,
it feel like engine sufficating. then its normal but again when I press on gas..
any ideas? Is it caused by air intake swap?
99 C2 coupe.
Check for leaks -- and it is best to reset the DME (got your radio code?) by removing the negative battery lead for 30 seconds.
Then the car will go through the re-learn process.
