I have an 05 Carrera S. The car has recently developed an intermittent squeeking noise that originates somewhere in the front end. It typically appears after the car has been driven for some time and it changes rate with car speed. Basically the rate of squeeking increases as car speed increases. It also seems to be more pronounces when steering to the left any amount and mostly goes away when steering slightly right. I have noticed that when the squeek does appear, any light to moderate braking will also replicate the noise. It seems like it's coming from somewhere around the front axle. Has anyone had this issue before? Any ideas as to what could be the cause? Thanks.
2005 Carrera S, Blk/Blk, PCCB
