Hello,
I've checked the search area and can't find a quick answer. Can someone tell me what the size of the OEM Sway bar is for a 1999 996 C2 is. I'm told that they can be 18.7; 19.8; or 20.9 mm. My Sway bar is stock and should be the basic size that came with the car new.
Thanks, in advance, for any help.
Patrick
NOTE: In case anyone would like to know. I have found out that the "basic" size of the REAR bushings are 18.5mm. Porsche OEM number is 996 333 792 24 (will need two of them). Also, the correct number for the Drop Links (same number for both) is 996 333 069 04.
Patrick
Edited by Last Car
