I replaced a leaking coolant reservoir tank 18 month ago with an OEM tank and it is leaking again. Is there anything that could be causing that? Also, can the crack be fixed with epoxy?
I do not know of anyone that has fixed one with epoxy - oil filler pipe yes - coolant tank no.
What tank part number did you get? There have been 5 or 6 tank design changes.
The tank part number is 996 106 147 56.
That is the latest tank so unless it damaged during the install it would be unusual for it to leak again.
I would double check where the leak is coming from.
Thanks Loren, I will check further and pressure test the tank again.
