Sounds like your oil level sensor is bad and needs to be replaced.
Do you get no bars when you first turn the key on (during oil level measurement)?
No that works fine. It onlt happens while I'm driving. A beep will go off and I'll get the message "oil indicator failure" on the dash.
Has the cluster been out of the car - if so, then recheck the connectors.
No the cluster has never been out of the car.
Well you could try reseating the cluster connectors.
The same signal comes into the cluster for both the startup reading and the OBC messages.
I'll try that. Thanks.
