Looking for some help/insight into an issue that just started in my '01 Cab this week. When the car is off, key out of ignition - randomly I will start to hear the cab top control module "clicking" rapidly (like every second for different durations - sometimes 10 secs, 15 sec, etc...). Everything operationally works opening and closing the top..its just when its sitting idle I hear this relay clicking.
Is it a bad microswitch or has that control module just started dying a slow death. I took off the back cover tonite just to take out the smarttop to see if that made a difference (it didn't) and the module is HOT! That relay in there is clickindurations - sometimes 10 secs, 15 sec, etc...)
Is it a bad microswitch or has that control module just started dying a slow death. I took off the back cover tonite just to take out the smarttop to see if that made a difference (it didn't) and the module is HOT! That relay in there is clicking like crazy so I'm sure eventually something will give!
Any insight from Cab owners is appreciated! Thanks,Will
