Currently the are developing a carbon intake box for my 2002 Porsche 996 3.6 Liter. I just want to make sure that the diameter of the hole for the Mass Airflow meter is correct and seals up tight.
Does anyone know what the diameter (in cm or mm) is of the MAF sensor out of a 3.6 Liter 996?
The diameter of the connection hole for the MAf senior is 34mm (I think). Can anyone double check this?
It is not just a round hole. There is a flat side to control the orientation of the MAF.
