i have an 06 turbo s and it shows there is a mis-firing i have bought the coil pack and want to make sure i change the correct one out and have search on the site the only way i can figure out and looks different than that want i have seen. Is the order
front 2 4 6 8
1 3 5 7
If not PLEASE HELP!. also do you know as soon as it is replaced will the ruff ride go away or will something else have to be done if that is it.
front 2 4 6 8
1 3 5 7
:welcome:
Give our search a try next time...
Firing order
If you pull the coils out and the last two numbers are 03 or higher then Porsche says to only replace the coils with a fault code but I still agree to replace them all. If bad coils is the cause of the misfire then the rough running will be fixed immediately. There are other things that can cause a misfire but coils are the most common.
