I have a 1999 Carrera 4, six speed. At times, I lose the accelerator input but the engine still idles at about 950 rpm. This seems to happen above 8000'. Turning the ignition off and then back on restores the accelerator input. No Check Engine light on. I had to turn the ignition off and back on about six times in order to get up the mountain. I reside at 9150'. Thanks.
Bernie
0709101836 MST
All the C4's have e-throttle, C2's only after 2000. There must be something happening with the e-throttle. Not sure if this is in the pedal electronics, the DME or the throttle body. Maybe another member knows how to trouble shoot this.
