Hi: I took a look at coolant level; believe its one with the blue cap on upper lefthand side of engine compartment; its below the minimum level; is there any special type of coolant that I need to add? Car seems to be running fine here in Arizona with temp guage usually staying around the 185-190 mark.
Safest thing is to use the OEM coolant, which you can get from Sunset, a board sponser if I am not mistaken..........
