Well after all the trouble I had with my 99 Boxster. I have now replaced the 2 before cat
O2 sensors. Now when I start the car it idles fine and once the engine is warmed up the car drives just fine. But if I try to drive it cold the car misfires and runs with almost no power and it throws the P1117 code no CEL thou. Now while the car is cold it should be in it's closed loop section of the fuel mapping so even if the O2's are bad it should still run okay till then. Any ideas? Thanks in advance.
