Over the course of the last week I've had a slew of minor problems with the e-brake light and now the convertible top won't close. Check light came on very intermittently at first and I could tap the e-brake handle and it would shut it off. Now the e-brake light stays on with the exception of the time when I have it engaged(grrrr...). I'm assuming my convertible top problem is based in the e-brake problem but I'd love your advice before I start taking it apart. Any suggestions are greatly appreciated. Cheers.
:welcome:
Do a search here and you will find instructions on replacing the microswitch. You are lucky - usually it breaks and then you can't put the top up or down.
