Hello,
I have had my '05 Cayenne S for about a year. Ever since my radiator hoses blew and were replaced by the new ?aluminum ones, I have noticed that when the car is started for the first time each day it starts out in D1, instead of D2 as it has always done. Sometimes even again at the end of the day. Everything else seems fine, fluids etc.
Thoughts?
Hi -- 1st gear start when engine is cold is normel. Probably always did that but you may not have noticed, or your thermostat was not calibrated/broken and was fixed along with your new pipes You can seach and find a ton of posts about this. Be sure to seach in the Cayenne 9PA/9PA1forums -- that's where Loren will probably move this one.
Edited by odix
