I tried submerging them in oil and pumping them prior to fitting, but they were extremely stiff to pump and I doubt very much ended up inside. Most of the oil ended up on me as I fitted them.
Is that vibrating also normal with unfilled tensioners?
Because the chains are running somewhat slack, the cam timing (read cam deviation values) are probably well off at the moment, which will cause the engine to run poorly.
OK, engine is running at the moment, has been going still noisy and rattlyabout 10 mins, camshaft deviations are 0.30 and 0.06 degrees.
After 10 mins, all the rattling stopped and the engine started running very smoothly. Cam deviation didn't change in Durametric though.
Thanks very much for the advice JFP, I was 20 secs away from getting it towed to a specialist who likely would have charged me like a wounded bull!!
That is what we are here for.  Glad you got it sorted out, now go enjoy the car.
Considering that 10W-X oils were until recently recommended for use in the arctic, I have never understood the need for 0W-anything, particularly in temperate climates.
I would suggest looking at Castrol Syntec 10W-40, it is what we use.
Hitting government mandated MPG levels - remember, the manufacturer is only on the hook during the warranty period. Mazda proved and burned themselves on that with the RX-8/Renesis...
