I just purchased a 2004 911 4S with 41K; it has been running great then just a couple days ago it seems that it doesnt have the power that it used to have. Before it was a smooth power band going through gears; know it sort of floats or hesitates; I did notice that the low fuel light came on a couple times. Do you think that the fuel filter is dirty? I changed the air filter; no leaks anywhere.
I was pulling in yesterday and in first coming into garage and it seemed to make a very low pop or rumble sound.
Any suggestions or ideas?
Dominci
Doubtful. The fuel filter on your model were not designed to be serviced or replaced like the earlier 996s were. I would say a more likely culprit is your air mass sensor is on its way out.
I would also suspect the MAF sensor but you need to monitor it's operation to see if it's at fault.
So how would I monitor its operation? Before when I would apply the pedal it was very responsive; now it seems sluggish and not smooth; auto parts store wants $120 for MAF and any porsche mechanic would charge that just to look; I do have an after market K&N intake http://www.knfilters.com/search/product.aspx?Prod=57-7000 ; not sure if that has an bearing on it going out; yet with 41K miles it seems rather early to go out.
Is there any spray of cleaner that I could use to clean it??
Ok; so I unplugged the MAF and drove about 5 miles and it ran great; good power and no issues; should I assume then that the MAF is bad or going bad?? Had no idea that they ran $390 just for the sensor!!
Yes, you can try cleaning it with a commercial MAF/sensor cleaner -- or just replace it. It's $4.95 for cleaner vs. $482.76 (MSRP) for a new sensor.
Just cleaned the MAF and letting it dry; it really didnt look dirty to me; I guess its a given its not a good idea to drive it with the MAF unplugged???
Porsche has been running great since cleaning the MAF; fires up great and smooth power band all the way through..
Thanks for the info guys.
Dominic
