Help please.
My turn signal lever will no longer engage for right turns, but works fine for left turns. Think I need a new lever. Replacement seemed straight forward enough to me. However, when I tried to remove steering wheel, I encountered this situation, my wheel came off fine , but there is a base plate that I cannot figure out how to remove.
If anyone has encountered this setup and has solution, I would sure appreciate hearing from you.
I have attached picture of the base plate that has been the focus of way too much attention this holiday weekend.
Thanks for reviewing my situation, and hope someone out there can help.
post-15322-046835000 1278357683_thumb.jp
  • 4 weeks later...
Found my answer through Glen @ Pelican. Replaced steering wheel to base, minus the main holding nut, and gave it a good pull...wheel came off, replaced turn signal lever and all is well.
