I noticed today driving with top closed, the rear plastic window moving quite a bit. After further review, the plastic window is coming loose from the top itself. Originally it was glued, apparently this was the method rather than stitching. Makes no sense to me. Anyway, I'm looking at trying to get it repaired (stiched) or replaced.
Does anyone have any experience with this problem, a solution, or suggestions. I looked on line and found that I can getr replacemet tops for a $1,000. Then I need to installm it. My top is in perfect shape, except for the plastic window coming loose at the glue seams.
Help.
Dennis
