I have a 1999 911.996 cabriolet anda red warning light came on on the right side of the temperature gauge this morning. The temperature did not go up it was on the 8 in the 180. What does this mean? Is this a sensor to monitor fluid levels?
is it flashing? if so your coolant level needs to be topped off
yes it was flashing, then I think it stayed red when I shut off the car with the key in the ignition
