I saw 2 posts on Rennlist yesterday that said for a 2002 and newer tiptronic 996's that the engine must be dropped to replace the IMS bearing.
I am expecting my IMS bearing today from LN and was hopefull to install it myself thinking that I could just drop the transmission to install it. All posts I have read in the past have stated that they just dropped the trans, not the engine untill yesterday...
Any info would be appreciated, as I don't think I am ready to drop the engine & trans. myself as my first DIY on this car.
Thanks- John
Thanks- John
No, you do not need to drop the engine, just the trans. Have you done one of these before? Is yours a three chain or five chain engine (Pre or post 2003)? This more than just about swapping parts.................
Edited by JFP in PA
Keep us informed... I also have a my03 c2 and was told 20 hours labor by my local P-dealer... What is the true time and cost to pull the Tip Tranny????
That is ridiculous………….. Pulling the gear box (on a lift with all the necessary tools) is a couple of hours job. Granted, the Tip complicates the process a bit, but I have no idea what they are going to be doing for 20 hours………..
Counting their money?:offtopic:
Wow 20 Hours,
you can pull it -- and be down to the crank and start putting
it all back together long before 20 hours :-)
mike
Wow 20 Hours,
mike
That's what I was thinking Mike, if I had a tech take 20 hours to do an IMS/RMS retread, he wouldn't be working here very long............... One thing you need to be cognizant of is that most dealerships still think you have to “split the cases” on all IMS jobs, which is obviously not the case.........a bad pun to say the least.........
I would like to remind you that it is not possible to remove a Tiptronic gearbox separately without silly things to do on a 996 with M.B. Tiptronic. On a 996 with a Z.F. Tiptronic on the other hand, there is no problem at all.
RFM can you tell me the silly things I have to do to remove the trans. only? Car is on jack stands with alot of stuff removed in hopes of a person like you responding that actually knows why this can't be done.
I am on 3 different forums trying to learn how to attempt this- you are the first one to possibly say you may know the problems in pulling the MB tip of the 2003 carrera.
I was told indirectly from a porsche tech something about the torque converter bolts. Can not learn more since tech is on vacation.
I am willing to do silly things to remove it without removing the engine- wouldn't be the first time I did something silly!
Thanks- John
Edited by johonole
RFM is correct on this one. The ZF which was installed from 99 to 01 is readily removable from the car without removing the engine. The Mercedes Benz auto which was used from 2002 to current 997s even is another story entirely. The ZF trans bolts directly to the engine case. The MB trans uses a bell housing adapter plate between the engine and trans which makes separating the trans with the motor still in the car practically impossible.
Practically.
One of the problems you will run into is being able to secure the torque converter to the transmission as there is not enough room between the transmission and the body to insert the factory tool for this. So the torque converter will probably come out just enough to dump all of its ATF all over. The main problems with this are... ATF is #1 messy and #2 costly and #3 kind of a pain for a shadetree mechanic to top off correctly (you'll need a durametric at the least). Also getting to the screws which hold the transmission to the bell housing adapter is what is going to be silly. Get all of your wobble, universals and extensions ready because there is absolutely no room, even with the engine lowered. I know several technicians that have tried this once and sweared never to do it again.
Edited by PTEC
At PTEC interpretation, i can add nothing. Hope it helps.
Thank you Ptech & RFM, I now see the light. I will now start reading the pulling the engine section of the work shop manual.
This is my first DIY on the car, so I feel a little like I do when I am about to get off the plane in Las Vegas. Hope it turns out a little better than those trips.
John
What should I buy to lower the eng. & trans. with, an ATV jack or motorcycle jack, or something else?
That engine and trans is very heavy, you need something heavy duty to handle it.
I use the Porsche table and the tips put a strain on it.
Got a post on Rennlist that said an ATV jack from Harbor Freights works well so I'm on my way!
Still could use any info on the Mercedes tiptronic- my shop manual has nothing on it.
John
Edited by johonole
