Hi all,
Issue with my new to me 04 Cayenne S
Tip, shifts fine no problem in automatic mode, works perfect in manual mode using the steerting wheel controls but if you want to use the shifter it will only downhift if you push hard, it will not upshift.
Scanned with duranatic and no codes. Some kind of bad microwitch?
Thanks!!
I had a similar problem on the right steering-wheel tip controller -- the entire piece of the center steering wheel was replaced -- which includes both tip switches. It was gummed-up from a spill from the prior owner, purely a mechanical issue. It was a thick gooey liquid that congealed. Like a chocolate syrup. It was a CPO repair -- luckily the dealer noted it as an issue to be fixed when they converted the vehicle to a CPO. We happened to purchase the vehicle before they had time to do all the work.
In hindsight, I should have asked for the old part -- they may not have offered because it contains an airbag which is basically an explosive and they might not have wanted the liability of giving it to me.
From what I recall no specif tip controller part # exists -- you need to replace the entire steering wheel center -- airbag and all. Let me know if you need that part number and I can look it up. If it's expensice it may not be worh the cost to repair -- if you don't use the wheel-mounted tip controllers a lot perhaps it won't bug you too much to leave it the way it is.
Thanks for the reply Odix, but the problem is in the shifter, the Tip buttons on the wheel work fine. I suspect it's a similar issue. Perhaps something spilled into the console by the shifter.
Best,
Marc
Sorry abut that -- misread your first post. Hmmm, not sure. Info on how to pull the plate around the shifter is here in Renntech. You could do that and see if evidence of a spill is there and stat ruling out issues.
I tend to use my stick for shifting more than the steering wheel controllers -- like on curvey mountain roads so I totally understand why you want to resolve this.
Edited by odix
  • 8 months later...
Best,
Marc
Marc,
Did you ever get resolution on this? I have an '04 and it is doing exactly as you describe as well.
Cheers,
MF
The buttons are part of the airbag and are not sold separately so if your out of coverage, deal with it or try to find a used wheel complete on ebay of the same color with a working set. OEM part is around $700
Mudman, thanks for that.
It is in my center console shifter as the wheel thumb shifters work as advertised. Just curious if there were microswitches in the console for the manual stick function or if it was a programming issue?
mf
