I have a 2003 C2 Cab. No Mods. 40,000 miles.
I started getting warning lights just driving along at any speed. The lights say "Break Distribution Failure" and "ABS Failure" they blink for a second then go off. There is no noticeable change in the breaking. I had new break pads, discs and sensors in the garage ready to put on- so I did that all they way around just in the slim chance it might be a sensor. That didn't help. I have the durametric code reader. Any ideas of what this might be or should I go to a dealer
I have searched around for hours- sorry if this topic is fully covered somewhere I missed! Any help is appreciated!
Darin
I will check the durametric as soon as I get a chance. The break lights work- I also noticed two other warning lights at lunch, the check engine and a message that said system failure- or something like that (it only flashed for a second). These don't stay on the just beep and flash for a moment. The MAF could be the problem as I have occasional super jerky early morning starts in first gear...
Thanks Loren!
Edited by drhollings
You might have a failing ABS control module but you need to check for codes in all modules and post them please.
I haven't had a chance to attach the Durametric yet but I have new info
While working on an unrelated roof rattle and roof hook refusing to latch issue. (sigh). The failure lights began to flash. While this was happening the car was cycling the rear wing! Any ideas?
I will attach the Durametric when I get the power suppy for my pc found!
Here are the codes out of the Durametric. It is only the second time I used it- but I think I got them all. I would really appreciate any help in making heads or tails of this!
9X6 ABS 5.7 Selected
About to get fault codes
moduleType = MotronicDME78
DTC Count = 1
Fault Number:P1601
Description:Porsche fault code 660 - CAN timeout - instrument cluster
Displaying infomation about Motronic 7.8
Porsche part number 99661866015
Supplier part number 0261206579
Software version number: 004161004620
Data Version 0041610046203613
Number of ignitions range 1 1274 / 1178h
Number of ignitions range 2 70 / 661h
Operating hours counter 1358
VIN: WP0CA29993S65XXXX
Type ID DME control unit __996US03
Order type 996310
Country code C02
Engine type 9603
Engine number 66302206
Transmission type G9601
Transmission number 1266290432
Radio code 0
Body color/convertible top color 92U tb
Interior equipment AA
Motronic 7.8
Current Fault Codes
P1601
ABS/PSM 5.7
Block 80 7F 1A 12
Block 9F 5A 9F 07
Block 91 5A 91 09 96 35 57 55 05 09 96 61 81 15 00
Instrument Cluster
Current Fault Codes
9110
DME control unit
Status: not present
9111
PSM/ABS control unit
Status: not present
Alarm
Current Fault Codes
33
Interior sensor faulty
Status: not present
Frequency counter: 1
60
Central locking limit position
Lock not reached
Status: not present
Frequency counter: 2
54
Radio receiver defective
Status: not present
Frequency counter: 8
Has the cluster been out of the car lately?
You get similar problems if one of the connectors is not properly locked down.
I would reseat them all - clear the codes and see if they come back.
Unplug all connectors for the cluster and abs unit, the simple act of resetting the plug might cure your problem but I think you'll need to replace the abs control module in th elong run.
Oh Renntech joy!
The cluster had not been out ever but I went ahead and reset all the connectors and cleared all the faults and all is as it should be. Took a spin around the neighborhood with a great feeling having conquered a problem with the help of friends that would have cost me a grand at the dealer.
Thanks Loren and Wvicary!
post-21040-070788000 1278040609_thumb.jp
Epic Fail- the warning lights are back. (uhg) (ABS failure- break distribution failure- check engine light) What is the next thing to try?
DTC Count = 1
Fault Number:P1601
Application closing at user request
DTC Count = 1
Fault Number:P1601
Operating hours counter 1359
VIN: WP0CA29993S65xxxx
Order type 996310
Country code C02
Engine type 9603
Radio code 0
Sorry to hear that.
P1601 CAN timeout instrument cluster - signal implausible
P1601 CAN timeout instrument cluster - open circuit
Possible fault causes:
- Wiring harness faulty
- Plug on instrument cluster not connected
- Instrument cluster faulty
Note:
- If all CAN bus faults are stored, there must be a short circuit in the CAN bus wiring.
- If one CAN bus fault is stored, the cruise control system is out of order.
- CAN bus faults may be caused by a control module reset. The fault is then indicated as "Not present".
Every time I had this fault return on VW/Audi it's been the ABS module thats needed replacing. Porsche uses the same system so I'm sure the fix is the same.
I have a feeling it may be the ABS Module. Come to think of it just before all this started I was getting some weird shuttering on a few very low speed stops.
A few more questions...
Is replacing the ABS module straight forward?
If so where is the best place to buy one? (online USA)
Is the procedure described anywhere on this site? (I couldn't find it)
Again- thank you thank you thank you!
The first time I replaced one( an Audi) the unit cost $5000.00 CND which included the complete ABS module,pump motor and valve block. Since then they have a rebuilt unit that sells for $600.00 CDN which is just the control module. As Loren stated, exhaust all other diagnostic avenues before replacing the unit. This is a complicated procedure and one of times I recommend getting an opinion from the dealer as they have the correct test equipment/experience and possibly find another source of the fault.
As for replacement, just replace the control module which is only held on with a few torx screws and don't open the brake system hydraulics. Perhaps you can source a unit through an autowrecker.
I am kind of out of ideas. I guess I will take it to a shop on Tuesday. (uhg)
Thanks for the ideas though.
When I find out what the problem is I will report back.
I just picked up the car with a brand new alternator! (548.00 parts) (270.00 labor) The specialist said that it was a common problem. On the way home all the lights came on again! Back to the shop next week. Nice...
I have a loaner instrument cluster in for the weekend. So far so good no warning lights. If this holds out until Monday they will send my instrument cluster in for repairs. ($650.00) The loaner instrument cluster must be from a hardtop because the top wont go down. On the bright side it only has 8000 miles on it.
The instrument cluster was "repaired" at the cost of 650.00 plus tax. That did the trick. I couldn't get any additional information about what got "fixed" but it's working so I guess that is fixed enough for me. What a colossal pain in the butt. Thanks all for the help!
  • 2 months later...
Is P1602 pretty much the same as P1601?
My SpecBoxster race car is having P1602 right now.
Of course, it is a race car, most of the stuff are disconnected.
But if it is affecting my ABS, I will need to address the issue.
Fault Number:P1602
