Hi all. I have 2000 996 cabriolet. Yesterday my daughter closed the passenger door and it sounded funny. I walked around and the window was barely hitting the plastic on the convertible top, but it was enough to keep the window from sealing against the gasket. I re-shut and it closed fine. What bothers me is the window doesn't appear to drop down an 1/8 of an inch or so when you open the door like it does on the drivers side. So I'm not sure if it's an adjustment issue or if whatever mechanism is used to trigger the drop is bad/out of adjustment or something else. Any thoughts or suggestions? It's just an annoyance right now, but I'd rather solve sooner rather than later.
Edited by vfrpilot0
If it is only on one door, AND "it" (no 1/2" drop) does not happen whether you pull on the inner OR the outer door handle, then it is most likely being caused by a faulty or failing window regulator.
The window regulator's cable assembly ends up stretching or the cable starts to fray a bit and that amount of play is sufficient to eliminate or greatly reduce the 1/2" drop needed to clear the part of the frame of the convertible top directly above the window and sometimes also not to go back up enough to make a good seal when the door is closed with the window up. That can produce wind noise at speed.
One way to help pin down the cause is to see if, after the window goes all the way up, you can press the top of the window down and get a resultant downward move of a fraction of an inch. If it's solid as a rock, it may not be the regulator. If it moves down a little, it's almost certainly the regulator.
Replacement after examination is pretty straightforward and there are a couple of DIY's floating around here, including Wayne Dempsey's recent one of one or two days ago on his Pelican Parts web site, in a post here on RennTech.
Edited by 1schoir
Thanks. I will see if there's any play in the window first.
Regards,
Allan
  On 6/29/2010 at 6:25 PM, PAULSPEED said:
Sounds like the door latch part. Here is my DIY for replacing the latch
on a 997.
http://www.renntech....134-door-latch/
If you can roll the window all the way up but it dosn't drop
when you open the door, then it is the latch.
Good luck.
Paul
Thanks for the response. I'll see if there's play first and if not I'll go after the latch. Just curious...how can you be so sure it's the latch? Also, since I've owned the car(10 months) my windows have never dropped 1/2" as described above, they drop maybe 1/4" at most. Is this due to stretched regulator cables?
Allan
It should be about 1/4". When you lift the latch the
window should drop so you can open the door. Then
when you close the door the window will lift
1/4" to seal the door.
Check out a friend's Porsche car.
Paul
Allan
Alan:
If they are dropping "1/4" at most" you may not be getting the full drop and the cables may have started to stretch.
From the Bentley manual, at page 64-2:"... When the door is opened, the window is lowered approx. 13mm (1/2 in.) to clear the door seal."
Edited by 1schoir
All,
Thank you for the responses. I played with it today and the window does drop each time the door handle is lifted, but it doesn't drop enough(approx 1/8"). I surmise that it is cable stretch on the regulator and I'll see about adjusting it one day when I have a couple hours to disassemble the door. Thanks again - it's really nice to be able to get sound advice on these things - this is my first Porsche and the little things that have popped up in the past year have all been solved via postings on this site.
  • 2 years later...
Thanks Maurice! :)
Thanks Maurice! :)
Glad you found a little nugget in that description that makes sense! :eek:
