I need to replace the bulb in the right front side marker and need to know how this is done. Might even replace the ambor lenses with clear ones.
The entire light assemby comes out and is replaced for either the amber or clear... the bulbs do not get replaced. If you just grab firmly at the wheel well and pull the light towards you it will "pop" out and then you simply unclip with wire harness and then reconnect the new one and snap it into place. Hard to mess it up. See link for diagrams
http://www.renntech....__1#entry172750
Edited by danieldolin
  • 3 years later...
