I have a 98 Boxster w/ tip. As some of you know I have beeen having trouble with my cooling system after I replaced my water pump. It seems that the fans are not operating correctly now. I was going through fault codes with the Durametric and in Heating and AC code 20 came up, which is listed as Combi-interface Fault. I have not been able to find anything through search or my manual. Has anyone come across this before, or does anyone know what it means. Thanks in advance, Ed
I got a reply from Owen at Durametric about this fault. He explained how to diagnose the problem but I still don't understand the problem. Can anyone suggest a direction to go in the research the code and what it means or is it a dealer only problem? Thanks, Ed
Fault code 20
Interface to instrument cluster
Possible causes:
- Open circuit
- Short to ground
Open circuit
1. Unplug connector B from the heating/air-conditioning control.
2. Unplug connector III from the instrument cluster.
3. Connect ohmmeter to connector B 13 and to connector III pin 26.
Display < 5 ohms
Note: The wire is routed via the 12-pole plug connection on the heating/air-conditioning unit.
Short to ground
3. Connect ohmmeter to connector B 13 and ground.
Display: infinite ohms
If 0 - 5 ohms is displayed, check wiring harness for pinching and chafing damage.
First obvious check would be for a loose or disconnected plug.
