After a bit of seat time on the track, I decided to upgrade my brakes to Boxster S brakes. I am looking forward to red calipers and cross drilled rotrs to be honest - track is just an excuse :)
I am getting calipers / rotors / pads from a dismantler. Has anyone completed a brake upgrade themself? It seems that there is an issue with the rear rotors ... There is a machine shop nearby, so I could get the rotors machined on the inside if that was all that was needed. I also saw on one thread that 3mm square spaces were needed - but the thread was pretty old and the links didn't work. Finally, it also seems that all the caliper bolts need to be replaced.
Any advice is much appreciated.
