I have the stock 4-channel amp in my 99 Boxster and am looking to replacing it with a newer amp. I'd like to mount the new amp in the existing location just behind the spare tire. Problem is how to mount it, since the steel panel behind the tire doesn't appear continuous, as the new amp is wider than the stock amp and requires new holes to be drilled there is actually nothing to drill or mount the amp onto. It is really a steel frame (to save weight I guess).
Anyone have any thoughts about how best to mount a new map in this area?
Thanks in advance.
Eric
Edited by ericinca
I just made an aluminum bracket that uses the stock bracket mounting locations (2 rear bolts, and a tab at the front). The new amplifier attaches to the new bracket. It is wider than the stock amp (and bracket), but that doesn't really matter unless you have the CD changer that sits to the left of the amplifier
post-39135-019753400 1277952232_thumb.jp
post-39135-058933600 1277952241_thumb.jp
Edited by demick
