Just about to have my hard top resprayed black. Factory 986 with ear covers on outside aswell like to know if anyone has some photo's info on removing all the inside trim for respray and most important the two roof strip things with the rubber underlay in the grooves will deffinately have to be removed won't be painting over any rubber. Also is the hard top steel or aluminium? thanks for any info you can supply. Like to know what parts to remove first till last, times not a problem just want it done in the correct manner..........Have all the torx keys ect if needed BUT ready need to know how roof strips and rubbers are removed thanks heaps for any info, someone out there must have done this before ..... :unsure:
Roof strips pop right out - there are plastic clips (~4) under each strip that grip on threaded studs protruding from the channel under the strip. Replacement clips are cheap - plan on replacing them for reassembly.
Rubber is screwed on with each screw cleverly tucked under the folds of rubber. Some are real tough to find. Consider leaving the rubber in place and tape it. You can loosen it to better mask for painting.
  • Like 1
Artster your a champion buddy thanks heaps needed to know that. Will help heaps hate pulling if there is a screw somewhere to take out first or I'll spend time looking and there's none... :thankyou:
