What is the appropriate minimum RPM for the 996 manual transmission in gears 2 through 6?
I assume first gear has no minimum other than the kill factor at about 1k RPM.
Does the minimum RPM change for each gear after operating temperature is reached?
The reason I asked is that I read somewhere (can't remember where, exactly) that lugging the motor contributes to RMS and IMS leakage and failure. Any truth to that either?
Thanks for your replies
I think low-speed lugging was only a concern with the flat-four Carrera motors with roller bearing cranks. I keep my revs between 3K and the redline, and so far, it's been oil leak and explosion free.
Something I read, somewhere, suggested the RMS and/or IMS seal issues occur with the 996 flat 6 engine incident to slower speeds. So, I'm wondering how many RPMs are too few, or too few to begin a hard acceleration from, in any gear. I'll be surprised there's not some guideline on this.
There was a post suggesting that those who run their cars in competition events don't have the problem. That's all the excuse I needed to drive the bejeezus outta mine! On a percentage basis, IMS/RMS failures are actually rare. Do a search; the subject has been thoroughly covered before.
According to this article http://www.lnengineering.com/ims.html It may be beneficial to keep the revs above 2500.
