Hello folks......,
How's your engine running.....mine is vibrate at idle just a bit.
The engine runs perfectly but you can feel the vibration
I replaced the engine mount, spark plugs and all the filter..
The vibrations are less then before but you can still feel it.
Is your engine runs the same
Robert
2000 996 C4
Robert,
I noticed you found my post about engine vibration at 1000 and 2000 rpm and replied. Your 2000 996 has an idle control valve that may need cleaning. You might also get Durametric to see if something else is going on with the mixture, o2 sensors, valve deviation, etc.
George
Edited by george996
