hi -anyone have instructions how to remove the trunk mounted cdc3? my magazine jammed inside it and need to replace - thanks, larry
Larry:
I just removed mine the other day. I'm going from memory here but there are only 2 bolts holding it to the ball wall. Be careful not to loose the rubberized nut/grommet which is attached to the bodywork. After that there are a couple of screws in front, just in front of the door. The whole unit then just slides forward. You'll then see 2 RCA plugs and another connector.
Hope that helps. Very easy.
