Removing the little black air pump first will make life MUCH easier.
Reinstall torque stabilizer bolts to the body and to the bracket at 44 ft. lb. each. The bracket to engine torque is 23 ft. lbs. on the biggest, fattest bracket bolts (M8 x 45mm) and 7.5 ft. lbs. on the smaller of the bracket bolts (M6 x 40mm).
New plugs are torqued to 22 ft. lb. w/ reinstalled old plugs to 19 ft. lb.
Coils themselves are torqued to 7.5 ft. lb. and the Design Cover fasteners to 3.5 ft. lb.
The secondary air compressors on the firewall are torqued to 7.5 ft. lb. and I removed them from their brackets and used packaging string looped through a bolt hole to the hood to hold them up and out of the way.
