Carbon Fiber Door Sill Repair
I have had some cracking in the driver's side carbon fibre door sill that recently appeared to be spreading and the resin coating lifting. The following outlines an 80% fix (in my estimation) using fiberglass resin available at most auto parts stores (3M Bondo Fiberglass Resin). I have never worked with resin before and would rate this relatively easy to do, but I learned a bunch doing it and will share herein. Total cost ~ $20 Total time – 2.5 hours (+2 hours drying time for the
Edited by fbgh2o
looks nice! mine had cracked a lot more so i removed the panels and twisted the c/f till all the shiny layer broke off. IMO it looks nice without the coating since it looks matte. the only thing is the "carrera" script comes off with it. but i can cut new ones with the vinyl plotter.
