Hi. Good Morning. Can anyone guide me on how to remove the boxster(2007) trunk opening button panel beside the front driver seat? I accidentally dislodge one of the buttons and need to fixed it back on. thanks
1. Take off plastic caps 1 and loosen the fastening screws 2 of the scuff plate 3.
2. Lift scuff plate 1 using a plastic wedge and pull off upwards.
3. Checking fixing clips 2 on the underside of the scuff plate 1 and replacing if necessary
4. Releasing plug connection on actuating switch and take off scuff plate.
  • Upvote 2
Thanks a million to Loren for a very simple and clear instructions. The button is back in place now. I also found out that the screw-head needs a 5mm allen-key.
Cheers
Cheers
It's actually a Torx bolt. Sometimes an Allen tool will work, but often it will strip it out if it's in there really tight.
-Wayne
They mostly use Torx, but in this case, I think they are Socket Head Cap (Allen) Screws.
It was a Torx on mine - just looked it up in PET, it looks like they changed the screw type somewhere around 2001 to a different style of screw. So, it looks like we're both right! :)
-Wayne
