I just replaced the water pump- the bearing was shot. The idler pulley is spring loaded. What else should I be looking for to ensure proper tension? Thanks for your help.
Nothing that is how it works.
I would however check every pulley for noise and wobble. Replace any that are suspect - a broken pulley can cause all kinds of damage.
If you are really interested in the belt tension, there is a $200 tool that measures it by the amount of belt deflection...............
