All you need is the aircon panel surround trim, part number 996.552.339.00.01C. The cable in the loom is plenty long enough. When you unscrew the panel from the top position there are two plastic brackets which come out. Discard them, as they aren't needed to fit the panel to the bottom slot.
Thank you Sir!
