04 CTT, entry and drive suddenly stopped working.,...
used the tool to check and its a code 3, no communication with the module, the remote still works button can lock and unlock the car
its just holding the handle the door will not lock or unlock or the dummy key no longer start the car
What do you guys think?....
LOW battery power that causes all these?..... however I have the car started and used the tool and it still cannot find the module
You can always try with key #2, or replace the battery inside the remote, to start with.
TRIED Every thing still the same!
the dummy key no longer start the car.
Disconnect the ground strap in front of the driver seat for approx. 5 minutes and try again, if the system still does not work you will need a PIWIS diagnostic tool. Hope it helps.
Can you tell me more about the ground strap? ., do you mean the battery ground? or just the ground to that part of the system
The battery is under the drivers seat - so I am pretty sure he means the battery ground.
As Loren said, the ground strap is located under the carpet, just in front, right side of the seat.
