I found the tabs on the carpeted cover, but I don't know what to do next. Something's apparently loose inside and rattles around with a distinct metal-on-plastic thump and clatter on hard right turns. '05 C2S 6-speed.
Hi 355,
Gently pull off the woofer port covers on either side, exposing two Torx screws. After removing those the unit should slide out just fine.
The covers are for the LATCH car seat system, there's nothing you need to remove there.
Mark
Hi 355,
Mark
Ah. Many thanks Mark. The port covers came off easily and exposed the screws.
