I just got cel along with P1128/P1130 codes. I have read many of the posts on the subject but wanted to what would be the most likely cause? seems to run fine with the exception to a large puff of white smoke.
If you've got 35-60K miles and have read a lot of posts on the subject, cleaning the MAF is a good place to start. If the problem goes away, you'll know the answer with a high degree of certainty
Check the J-tube. Possibly the the AOS.
