Doe anyone here have access to the Cayenne Technical Manual (9PA) 4/6/7/9 > repairs, 70 03 19 Removing and installing rear luggage compartment side panel lining?
I'm trying to gain access to the OEM CD changer bracket in order to mount my CDC4 CD changer.
If anyone can provide me with this section of the Cayenne Technical Manual or refer me to someone who has access to it, I would be very grateful.
Thanks in advance.
dude. i am sure u don't want to do this by yourself. i just got my one installed by myself. without remove the pannel.... it took me 2 and half hours. and 30 mins on optical line......
My '05 CS is pre-wired. Just need access to the OEM mounting bracket. I was able to angle the CD changer in sideways and connect the two plugs (power/control and optical). The CD changer was "recognized" by the head unit. BTW, I have Nav and Bose in my CS.
How were you able to mount your CD changer and plug it in without removing the side panel?
  • 2 months later...
did you finally get the removal instructions? I'm in the same situation and look very hard to remove this panel.
any information is appreciated.
thanks
