Hi, looking to update my 2000 Boxster S to the ambient lighting equipped 2003 model review mirror. Can I please get a part number and rough cost for it? Has anyone done this update before?
David
  • 4 months later...
Just an update... but it was not the rear view mirror I needed. For the LED ambient lighting you need the 2001 Interior dome light assembly (986-632-053-00) which replaced the one in my 2000 Boxster S. It was a directly replacement for installation but uses a different wiring connector. All I did was solder some wire leads to the new light connector and then used standard spade connectors on the other end to connect up the factory wiring connector. It works great! David
