Yes, I know this seems like a well worn topic but hopefully this will be a twist and I can't seem to to find the info I'm perhaps needing.
I have the typical frothy oil in the coolant, but no water in the oil. So, I'm hopeful that I have one of two problems:
Bad oil cooler or bad air oil separator
It seems from these forums that both of these have water and oil in close proximity and that a failure could cause my symptoms.
First, needing thoughts as to my theory. Are these likely issues? Can oil enter water via these components?
Second, I need full replacement proceedures or a DIY on these. I found a great DIY on water pump that I used last week, but can't seem to find a DIY process for these components. Any advice would be appreciated!
Just don't tell me I have a blown engine :-) Ignorance is blissssssssssss.
Either of these could cause your problem. However I have heard of a few people attempting to fix intermix problems by replacing the oil cooler and it didn't fix anything.
Are you sure that when you replaced your water-pump somehow you you did't contaminate the cooling system with oil?
ouch, sounds like a head gasket. been there, done that with my old Fiat 124 spyder. ouch. good luck, hope its not anything serious...
I would take your car to a GOOD Porsche indie mechanic that you can TRUST and have him look it over. It's a good sign that there is no water in your oil. I wouldn't drive the car anymore until you get this diagnosed.
If you had a cracked head you would most likely have intermix in the crankcase already.
Good luck!!!
The oil cooler on my factory rebuilt engine failed with less than 1K miles. Quite a mess and took the dealer more than a week using the factory cleaning solution to get it to run clean. So, oil coolers do fail.
Bob
