I pulled the DRL relay as other members suggested and it does disabled all the DRL, however, the license plate lights do not turn on even I turned on the headlights. I've searched the forum and google and it doesn't seems to be able to find the solution on this one.
Anyone has any suggestion? Is it possible to connect the license plate lights to the rear lights (not the break lights, the one that will be turned on all the time and will not grow brighter when you step on the break)
Many thanks! :D
I think you're going to find it's worse than that, the high/low beams don't work.
Put it back.
Worse
Put it back.
Worse
My low beam (xenon) is working fine, I haven't checked the high beam and fog lights yet. Speaking of which, I would check them out now dry.gif
Update:
I tested all the lights and they are all working fine, low/high beam fog lights etc. Only the license plate lights are not working after DRL relay is pulled. (They were working before I pulled the relay :))
Edited by chanda
