My remote key is flashing but my car is not locking or unlocking also my trunks wont open with my remote what is going on?
  • 2 months later...
Fault code 60 -- Central locking limit position 'Locked' not reached
Fault code 54 -- Radio receiver defective
Check the fuse first - C3 (15 A)
I would fix the fault 60 first. Unless the wiring in the door is damaged you may have a bad microswitch in the door lock.
Aftermarket radio?
Thankyou i will ck the fuse the radio works great and it appears to be factory everything else is good i have a durametic but it it has limits in this situation.My key is old but its all i have.This form has helped me with everything else thanks for all the info.
Is it not so that code 54 refers to remote/receiver (radio frequency) error instead of the car radio (in car entertainment) ?
Good point so a code 54 could cause a code 60 in the system can the reciever be re programed?
Is the remote reciever under the drivers seat ?
The central alarm control unit is under the driver's seat (left side, U.S. cars).
The antenna to receive the signal from the remote is in the A-pillar on the driver's side, under the plastic trim.
Regards, Maurice.
