hi, yesterday i start to feel when i acelerate hard , the rear suspention moves , ( the steering wheel stay steady but i feel the car taking to the right side a litle, i compared like a rack & pinon bad bushing)(going side ways but the steering wheel remain in the same position.
i take a look at the rear and front susp. and everything looks fine , bushings, arms shoks, etc. ( like a litle twist fron the rear) if any have a sililar situation, please tell me wath you find. thaks alot . juan from puerto rico
sorry for my english!
Hi Loren , by the way when i lift the car by the engine) i saw liquid coming from the rear mounts ( black fluid not oil, like corroed liquid) i ask a friend and told me those motor mounts are not idraulic, its that right ?
how many mounts have the car
also , i dont feel any vibration or somethig similar, thaks for your help , i always read your post and i kwow youre the guy.
The motor mounts do have oil in them and are known to leak. If you have oil leaking out of them it is time to replace them.
Thanks, but really concern to me that with just 28,000 miles that happens, is a 2000 996 c2 model.(the liquid dont smel or be squeze like all kind of oils.
dont leave any shinny mark on the garage when cleaned with a towel.
If you feel the car pull to one side or the other when under acceleration, this is usually caused by asymmetric rear toe (thrust axis isn't aligned with the axis of the vehicle). This could be due to worn suspension components or simply poor alignment.
