Hi All,
Please excuse the rudeness of my 1st post I will get around to introducing myself in the near future :cheers:
Anyway, my park assist is not making any noise,
I have searched the forums and so far all I know is that the noise is generated by the same speaker as the door open chime, which as far as I can tell I do not have either.
The car is bringing up no fault codes.
Can somoen suggest a possible solution, or point me in the direction of the speaker?
Thanks in advance,
Tomson :thumbup:
1) Quick speaker check = ignition on - lights on - ignition off - the speaker should work now.
2) Quick park assist check = ignition on - gearbox in reverse - does the reversing lights work ? - if not, check fuses/reversing light switch - if yes, use a PIWIS tester.
