Is this correct? From the WSM it says 10.25 (2.22) imp. gal
Is that 10.25 US quarts?
I recently had the engine draining for days while doing some work on it (RMS, IMS, AOS boot, Oil + Filter, Oil Pan Inspection and Reinstall, New Trans Mount).
Oil pan was removed, filter out for days, more puked out of the ims tube, chain tensioners as well - and it basically had a lot of time to "drip dry".
She took nearly every drop of 10 quarts (after a good warm up and carefully checking dipstick) and looks like it could use more, perhaps another .25 to .3 quarts.
The on board computer says it is now about 2/3's full (guessing the low mark is about 1 quart low) but I always trust the dipstick over the OBC.
Had it out for a 10 mile drive, everything looks good.
Just not used to adding that much oil after a change, largest oil change I've done maybe 8.75 ish quarts tops (really anal about drain times and having a warmed engine while draining), anyone else encountered this before?
Thanks.
Edited by logray
On a 3.4 liter I would add 9 US quarts (8.5 liters). Run it a little, shut down, wait, check the dipstick.
A 3.6 liter actually get less - 8.7 US quarts (8.25 liters.
Thanks Loren, I am thinking those are oil change quantities. Most oil changes don't involve pulling the oil pan, removing the chain tensioners, ims bearing, then allowing the engine to sit for several days to drain.
I definitely add "a little at a time" until the dipstick reads at full...
10 quarts of liquid gold Mobil-1 5w40 though... that's where I was a little concerned and started looking more towards engineering specs in the work shop manual rather than oil change specs.
edit: sorry, 1999 3.4 996.
edit: the bottles of mobil 1 say 946ml which is .99 quarts. Guessing that I'm losing a few .01's in there not letting it drain completely. If I could lick it out and spit it into the engine I would at these prices. In any case the 10 bottles I'm guessing perhaps .95 quarts of them drained. So that would be more like 9.5 quarts and according to the dipstick still looks like it needs another .2 to .3 quarts.
Edited by logray
logray, i find this a little interesting. i have found that my 3.4 takes all of 9 qt's of redline 5-40 and still the dipstick is a little low, still taking a third of a quart. i also find the dash oil level meter to do all kinds of somewhat erratic things and have pretty much decided it's just for fun. and yes it's spendy, oil changes cost me 60$ a month without any oil burned, with a 6000 mile drain interval.
Logray- M y 1999 996 3.4 takes 9.75 qts. of Mobile 1 with a filter change and with as much as you lost, sounds reasonable. This is one line down on dash gauge and just almost full on the dip.Im'n not sure how much the pan holds.With all the oil lost in the'' Gulf oF Mexico"' from the B.P. thing what's ten quarts.
Cool thanks that makes me feel better someone else puts that much in, the thing just kept taking oil and I thought I must have done something wrong... maybe bad RMS or IMS seal or something... but no leaks from that work still and lots of miles since!
It looks like I've got a leak near the number 4-6 chain tensioner (hall/cam sensor? I have to rip it apart) and another small leak on the opposite 1-3 bank, on the outside of the variocam lid opposite the cam sensor for bank 1-3 (still trying to figure out what that thing is).
