Inadvertently pushed down on engine opening switch versus lifting. As a result the switch fell into the sill. It appears that I can simply gently rock the plastic piece the controls sit in and simply reinstall. What I am unsure of is if there are pins or something else that would break if I am not careful.
Also any advice on tires that are less noisy than current Pilots. Interested in experience with PS2's or others.
Thanks.
i had same thing happen- take off the entire piece that houses the two switches- there are
one or two torx screws in the side of the housing by the seat- remove these and piece comes
up and you can pop switch back in- found this easier than trying to fish the switch out and
pull it up w/o removing the entire housing.
