Does anybody know which fuse is the one that controls the gas filler flap? By activating the remote control i can see, from the rear lid, that the actuator is not moving at all, so i use the emergency unlocking way to open the filler's flap. Does anybody know which fuse controls the actuator, in order to check it?
Thank you in advance
PS : Problem solved, actuator mechanism replaced. Thank you
Edited by vgiaritz
