Hi, this is the second time I've replaced the battery in my 2000 Boxster. The first time the unlock code (0189) worked fine. This time though, I cannot even get the radio to power on! I tried holding down the power key for a few minutes and nothing! Help-how do I get the radio to turn on? Porsche Nut said "Check the fuse on the fuse panel and the fuse on the back of the radio." First, I have no idea where to look for fuse panel or how to pull radio out! Second, if someone nice :) can tell me that, I'll check. Will it be obvious if it is the fuse?? I'm a little clueless mechanically, but I can follow directions. Thanks in advance!!! I'd also welcome other ideas that don't involve going to the dealer!!
